Horse cabin lights
volcamp
Reg. Apr 2016
Posted 2016-05-30 11:43 AM (#167183)
Subject: Horse cabin lights
I have a 2009 bison 3 horse slant with LQ. The lights for the horse area will not work. I have verified that the 7 way is wired properly. Bulbs are good. The tow unit is a 2016 ram 2500 lariate with tow package. The towing fuses in the fuse box are in place and good. Any suggestions?
beeoerdog
Reg. Jan 2014
Posted 2016-05-30 11:49 AM (#167184 - in reply to #167183)
Subject: RE: Horse cabin lights
10010010010025
The horse cabin lights should operate with the LQ electrical system. Check fuses in the LQ.
huntseat
Posted 2016-05-30 11:52 AM (#167185 - in reply to #167183)
1000500100100100100252525
We fried our light bulbs in the stock cabin on the third outing with our new Featherlite trailer, a few years back. Only after a trip to the dealership did you realize we missed the first step...so, my question is have you checked the actual bulbs? If you keep blowing out blubs then you need to check into your electrical problems, but ours seemed to be a fluke.
Posted 2016-05-30 2:13 PM (#167186 - in reply to #167183)
Start checking continuity at each of the lights...:(
rfrank
Reg. Dec 2013
Posted 2016-05-30 2:33 PM (#167187 - in reply to #167183)
My Trails West has a fuse up by the battery. Its in the battery box, check it. Its the fuse to the lights in the horse area. I can't remember what make it blow. Something to do with dead batteries.
Posted 2016-05-30 10:27 PM (#167189 - in reply to #167183)
Does your truck supply power to the "aux" circuit when it is not running? Do you have power to this circuit supplied by the truck? One of our trailers had the stall lights supplied by the truck, with the LQ lights supplied by the batteries. This prevented the inadvertent draining to the LQ batteries if the lights were left on. You can test this by supplying power to the "AX" pin ( one o'clock position) when looking at the end of your trailer plug and a ground. A battery charger works well for this test.
