Horse trailer tires
Last activity 2009-01-29 10:20 PM
7 replies, 5337 views
RCK
Reg. Jan 2009
Posted 2009-01-29 5:53 PM (#98468)
Subject: Horse trailer tires
I'm hoping you boys can help me out. The horse trailer (3 horse slant, 5140 pounds empty, dual 6000 pound axles) needs new tires (235/85/16, E). I live in Colorado...so I'm assuming road heat won't be as much a problem as it may be for some of you.
Would you,
1. Get Goodyear Marathons even though they were made in China,
2. Get Carlyles even though they have gotten some pretty bad reviews,
3. Get Michelin XPS Rib even though you can't afford them, or
4. Get a good, LT, E range truck tire with a highway/all season tread.
Thanks in advance for your wisdom and experience.
Posted 2009-01-29 6:02 PM (#98469 - in reply to #98468)
Subject: RE: Horse trailer tires
1. Get Michelin XPS Rib even though you can't afford them, or
2. Get a good, LT, E range truck tire with a highway/all season tread.
ponytammy
Posted 2009-01-29 7:24 PM (#98481 - in reply to #98468)
500100100252525
It is cheaper in the long run to get an excellent trailer tire. Blowouts can damage your fender, brake wiring, scare the heck out of your horses or worse. Two different trail riding buddies had blowouts last year using older and inexpensive tires. One has a damaged fender and the other spent 2K on fixing wiring.
Edited by ponytammy 2009-01-29 7:25 PM
Posted 2009-01-29 7:56 PM (#98486 - in reply to #98468)
I'm not a fan of the no name chinese tires.   I suggest you get a brand name you know.
Goodyear, Goodrich, Michelin, Cooper, Firestone, Bridgestone.
Some tires from almost every manufacture are being made in china. But at least if you have brand name backing the tire you might get some help
With the no-name tires, if they have a bad batch come through, they just change the name and move on.
Posted 2009-01-29 9:08 PM (#98491 - in reply to #98468)
No Chinese, no Firestone Steelex.
Few people run their tires long enough to wear out the thread. Most tires die of old age first. Unless you drive an unusual amount, the expensive high mileage tires may not provide the return you may be expecting.
RCK
Reg. Jan 2009
Posted 2009-01-29 9:27 PM (#98494 - in reply to #98468)
retento, ponytammy, Painted Horse and Gard.....you are all wise beyond your years. Thank you for your comments. May you all be blessed with great horses,the wind always at your back, the sun warm on your face, and the rains falling soft upon your fields........
Posted 2009-01-29 9:36 PM (#98497 - in reply to #98468)
Sounds like an Irish blessing. And to you !
RCK
Reg. Jan 2009
Posted 2009-01-29 10:20 PM (#98500 - in reply to #98468)
gard, you are correct. Thanks again.
