LQ Trailer axles
Last activity 2009-02-23 9:05 AM
8 replies, 5231 views
texas06
Reg. Jan 2009
Posted 2009-02-22 10:21 AM (#99880)
Subject: LQ Trailer axles
What size axles need to be on a Alum trailer 4 horse 8 wide with 10 ft sw lq? Also what ply and size of tires? Thanks!
deranger
Posted 2009-02-22 12:50 PM (#99889 - in reply to #99880)
Subject: RE: LQ Trailer axles
5001001001001002525
I don't think I would be satisfied with anything less than two 8k pound axles.  As for the tires, you would probably be o.k. with load range E tires.  There have been a lot of threads on trailer tires, so you might look in the archieves to see what you can find?  Lots of good information in the archieves, you just have to spend a little time looking for it.
deranger
texas06
Reg. Jan 2009
Posted 2009-02-22 5:44 PM (#99907 - in reply to #99889)
I am looking at a C&C 4 horse with 10ft lq 8 wide. It weighs 11300 lbs It has 7000# axles and E rated 10 ply tires. Do you think that will be ok. What problems do you have if the axles are not big enough? Thank you
Posted 2009-02-22 6:47 PM (#99917 - in reply to #99907)
Originally written by texas06 on 2009-02-22 6:44 PM
Is that 11300# weight without horses and dry tanks, no feed and groceries? If so then I would say those load range E tires are going to be beyond maxed out. Load range E are rated at 3042# per tire, you got 6084# of tires per axle. Load range G will give you 3750# per tire or 7500# per axle. Load range G tires require 110 psi to obtain the 3750 rating. You need to be sure the rims are approved for 3750# at 110 psi.... This weight/pressure info should be stamped on the rim. Your best bet is to load the trailer as you would be traveling and weigh each axle along with the tow vehicle at a "CAT" scale, at a truck stop, then you'll reallly know what each axle weighs and go from there.
texas06
Reg. Jan 2009
Posted 2009-02-23 5:32 AM (#99953 - in reply to #99880)
Yes it weighs 11300 empty. 7000# axles  do not seem to be enough? The tires would be easy enough to change. What about the axles?
Posted 2009-02-23 7:34 AM (#99955 - in reply to #99880)
kym.... What's the GVWR number that's stamped on the serial number plate/tag? 14,000#? 16,000#? 17,000#? more?
I wouldn't change anything until you weighed the trailer loaded. You may have a pin weight of as little as 2000 lbs, or up to and beyond 5000 pounds..... Hard to tell about these LQ trailers and some of it depends on the size of your horses..... Do they weigh 800 lbs. each or 1500 lbs. each!!??
What size truck you using? 250/2500, 350/3500/ 450/4500,  SRW, Dually, ext. cab, crew, etc etc.??
Check the "BUILD DATE" on those tires. If they are 5 to 6 years old, I would be replacing them...... Here's my pick as a replacement  load range E and G, 235-85R-16 tire. Check your trailer rim rating before exceeding 80 psi air pressure.
Michelin XPS Rib LR-E.... 3042# at 80 psi
http://www.michelinman.com/tires/light-truck/xps-rib/
Goodyear G614-RST LR-G.... 3750# at 110 psi
http://www.goodyear.com/rv/products/g614rst.html
Weigh the loaded trailer and truck first and check the tire build date, no need in guessing what is sufficient for your trailer.
Edited by retento 2009-02-23 7:39 AM
texas06
Reg. Jan 2009
Posted 2009-02-23 8:00 AM (#99957 - in reply to #99955)
My horses weigh around 1150 to 1200 lbs. I would be pulling it with a 07 Dodge 3500 5.9 Desiel I am just looking at this trailer. I have not bought it yet. All I have is the vin#  The trailer is 1000 miles away from me. Thank you so much for your help. I am just trying to make the right choice.
Posted 2009-02-23 8:21 AM (#99958 - in reply to #99880)
  I hear what you're saying, hard to buy a big ticket item over the phone/internet, etc. unless you got someone that you really trust on the other end with their hands on the trailer.
  Sounds like it may be a nice trailer, if the "price is right", then get it, you'll have saved enough money to spend a buck or three on it, to make it the way you want. I would imagine that C&C would have installed more than enough axle and tire to carry the weight of this trailer when loaded...... You got more than enough truck to handle it, one of the last of the "good ones"!! A high horsepower Cummins 5.9 without all the smog junk!!
Edited by retento 2009-02-23 8:23 AM
Tresvolte
Reg. Feb 2008
Posted 2009-02-23 9:05 AM (#99965 - in reply to #99880)
If you have the VIN #, call C & C and they should be able to tell you the GVWR.
888-360-2310
