 Come on in 1087  Folks on-line
Horse Trailer News
General Discussion
Horse Trailer News
Max Brake Review
  Last Activity 2010-08-16 2:14 PM
0 replies, 1468 viewings
back reply
Navigate threads:
^ Top
Administrator
User Profile
Subject : Max Brake Review
Posted : 2010-04-26 8:45 AM
Post #119368
MaxBrake Hydraulic over Electric Variable Trailer Brake Controller and Trailer Light Tester
Trailer brakes are very important to me. Besides towing doubles (two trailers) around the country, I also live near the mountains in Colorado. Coming down the fast side of the Rockies, increases the need for powerful brakes.
Your truck has more power, your trailer has grown heavier - being able to stop all that dependably and safely is why I recommend MaxBrake. The most powerful and fastest trailer brake controllers activate with your trucks hydraulic brake system.  Big advantage having your trailer brakes engage with your truck brakes, not after.
When Ford came out with its first integrated trailer brake controller in 2005 in its Super Duties, it was hydraulic activated and still is, including the one available for the F150 for 2009. MaxBrake hydraulic over electric is a simple install, just one wire cable goes through the fire wall from the hydraulic sensor to the controller. The power supply is inside the cab. Don't let bleeding the trucks brake fluid scare you. It's just a couple of drops on the supplied "T" connection. Back before ABS, that's how most brake controllers worked. MaxBrake and ABS do not affect each other.  MaxBrake does not tie in to the ABS module/computers.
The closest you can get to MaxBrake is the Ford factory controller, but it doesn't work with hydraulic trailer brakes according to Ford until 2011 Super Duties. In Ford's first few years, under 12 mph, the gain would drop off and not give you trailer brakes at slow speed. Something folks on steep grades discovered. GM and Dodge came out with integrated brake controller options but are only electronic controlled, not working off your trucks hydraulic brake pressure.
Today's slant load horse trailers with large Living Quarters, are popular and heavy. Having a LQ is like pulling a loaded trailer all the time. Propane tanks, water, TV etc. keep the weight growing.
Trailer brakes have come a long, way and the MaxBrake is the leader in improving your safety, your horse's safety and comfort as well as the rest of the population you share the roads with. Trailer brakes are often neglected until there is problem. I've spent too much time with a flashlight in my mouth, sometimes in the rain, working on my trailer brakes, magnets, wiring, and fuses after I discovered my brakes weren't helping any. Heavy loads and shifting animals require that everything works, and surprises can be deadly. You won't find a better product for dependable brake and whole trailer management. MaxBrake can put your trailer at the same level of technology that your enjoy with your new truck.
The kit comes completeUnscrew one of the brake lines going into the brake master cylinderInsert "T" into master cylinder and reattach the brake lineBend by hand the steel line for where you want the sensor to attach
The steel line goes in the top hole of the "T"Attach the pressure sensor to the steel line...finger tightHave someone pump the brake pedal while you bleed the brake line at the sensor
Now you can attach the cable to the pressure sensorRun the cable through the truck fire wall in an existing...rubber grommet into the cab Back side of the MaxBrake controller, left, power plug, right, the pressure sensor cable plug, calibration button, right
Plug in the cables, attach bracketCalibration buttonManual grab lever, remember where it's atEasy to calibrate, now ready set, stop !!
The MaxBrake controller gives you a proportional trailer brake in relation to your tow vehicle. It achieves this by utilizing a pressure sensor mounted at the master cylinder that measures the output pressure of your tow vehicle. The pressure sensor utilized is compatible with all ABS systems used for any tow vehicle. It does not displace any brake fluid and it is the same sensor that many manufactures use in their Vehicle Dynamic Control systems for ABS. This measurement is turned into a signal and sent back to the actuating system on your trailer brakes. This is all accomplished using microprocessors; there are no pendulums or accelerometers in the MaxBrake. The MaxBrake controller easily attaches to the dash and is a truly intelligent computer brake controller.  Buy now
Why would you want a trailer brake controller that waited for the trucks reaction when MaxBrake engages with your truck brakes?
I thought overload springs were for overloading. Every load of hay will weigh different. How close to your truck and trailer max weight rating are you and can you stop in an emergency? As roads get over crowded, farm machinery, stray cows and teenagers test your stopping power and reaction time.
MaxBrake is capable of applying full brake voltage to the trailer even when the gain is set to the lowest setting. The driver sets the gain to the most comfortable setting allowing you to adjust softness or firmness of the trailer brakes.  MaxBrake remembers the calibration settings for the pressure sensor based on how you "train" the pressure sensor to your brake pedal. MaxBrake eliminates the annoying frequent gain adjustments necessary between loaded and unloaded trailer conditions. Since a full trailer brake is always available at any gain setting. MaxBrake provides the most proportional truck brake to trailer brake response available.
The MaxBrake is microprocessor controlled, it consistently matches tow vehicle and trailer braking requirements, reads the brake-line fluid pressure for the smoothest and best modulation. A manual override allows for finger application of the trailer brakes.
Heavy duty trucks like the Ford F650 and Freightliner M2 with air brakes can also use MaxBrake.  When you order, MaxBrake provides an air pressure sensor and an air tee instead of the hydraulic pressure sensor.
MaxBrake website
MaxBrake™ Features:
• Compatible with any trailer system up to 4 axles
• Forward and reverse proportional braking
• No leveling
• Power saving mode
Compatible with all electric/hydraulic trailers, look at your owners manuals for Ford, Dodge and GM with their integrated factory trailer brake controller. They will say "don't use with hydraulic trailer brakes.
• Calibrated to your brake pedal
• Free software upgrades (excluding shipping)
• Does not interfere with ABS brakes
• 5 year limited warranty
• Brake System Diagnostics: Dead Short Detection, High Current Detection, Total Amp Readout, Trailer Unplugged, Sensor Unplugged
Understanding MaxBrake's Intelligent Design:
  • MaxBrake is easy to install.  Calibrate the MaxBrake to your brake pedal and the vehicle installation is complete.
  • Once a trailer is plugged in, the MaxBrake detects if any brake magnets or electric over hydraulic motors are connected.
  • The harder you press your brake pedal, the harder your trailer brakes will be applied.  The softer you press your brake pedal, the softer your trailer brakes will be applied.  This is a very familiar and natural way to control your brakes, and this is exactly what MaxBrake is designed for.  MaxBrake give you total control of your trailer brakes at all times regardless of load size or speed, even in reverse.
  • MaxBrake also has a “fine tuning” adjustment knob.  This allows you to fine tune your ride using the CVBC (Continuous Variable Brake Control) adjuster.  You can set the CVBC adjuster anywhere between 0 and 100.  This guarantees you the smoothest ride possible.
    • The lower you set the CVBC adjuster the less brake pedal sensitivity will occur.
    • The higher you set the CVBC adjuster the more brake pedal sensitivity will occur.
    • Most users prefer a CVBC setting of about 35 to 40 for all towing loads.
How does hydraulic over electric work?
The MaxBrake™ brake controller uses hydraulic vehicle brake pressure to control electric trailer brakes. MaxBrake™ uses a pressure sensor installed directly at the vehicle master cylinder to monitor vehicle brake pressure. It is easy for the handyman to install the pressure sensor without any special tools. The pressure sensor does not affect ABS brakes. There is no hydraulic brake line to run into the vehicle cab. As the driver applies the brake pedal, MaxBrake™ monitors vehicle brake pressure and sends a variable output to the electric trailer brakes. MaxBrake™ makes your trailer brakes feel like they are attached to your brake pedal. You have complete control over how much or how little to apply the trailer brakes. Buy now
This kind of trailer (above) is very easy to overload. Any heavy trailer needs MaxBrake powerful fast trailer brake controller for electric or hydraulic trailer brakes for maximum stopping speed and power. Great combination with disc brakes. Look mom no magnets!
MaxBrake trailer brake controller will run electric or hydraulic brakes and talk about power! When you are applying the brakes, you don't know you have a trailer on back! The is no jerk when the trailer brakes kick in. This was pulling a trailer with electric brakes too. The controller is programmable to fine tune your trailer braking requirements but why? It's automatic and self adjusting, displaying trailer brake system problems. MaxBrake does exactly what your foot does on the brake pedal regardless of the trailer type or load.  The driver presses the brakes harder or softer to meet all braking needs.
You've probably heard how great pendulum style brake controllers are. MaxBrake trailer brake controller goes one better by sensing the truck's pedal pressure (hydraulic pressure) with their solid-state pressure sensor. In other words the trailer brakes are activated at the same time as the truck's brakes. Now how can you beat that for speed?
You've got to see it to believe it. Walk behind your trailer with the MaxBrake remote and test all your trailer lights by yourself ! Simply installation, took us 5 minutes.
Check the brake lights, running lights, blinkers and hazards all by yourself. How else can you check all your lights by yourself?
Every trailer you plug your truck to, can be tested by one person. Always wondered how folks tested brake lights by themselves. I can't run that fast. I guess you'd have to back up to a white wall or something.
Every trailer dealer needs one, or for that matter anyone that tows without a co-pilot.
Just a "T" connection, box  and remoteUnplug the back of your trucks trailer socket connectionPlug the "T" connection to the socket and.... the truck's trailer wire harness
The box (brain) zip ties out of the way behind the bumperThen just play with your remote and be safe. Check the brake lights, running.... lights, blinkers and hazards all by yourself. How else can you check all your lights by yourself?
MaxBrake website    Install review by H. Kent Sundling
back reply
Navigate threads:
Administrator
Forum Moderator
Registered User
Unregistered User
E-Mail this thread to a friend
Toggle e-mail notification
