Spare Tire Mount on a 99 Sooner
Last activity 2011-05-11 1:55 PM
3 replies, 4058 views
suhz88
Reg. Mar 2011
Posted 2011-05-10 2:31 PM (#134025)
Subject: Spare Tire Mount on a 99 Sooner
I just bought a 99 Sooner and the spare tire mount has me stumped. I've never seen one like it on any of my other trailers. It has the shelf to set the spare on but behind it is what appears to be a vertical pin slot welded to the frame. Any one know what I need to get to make it work? Thanks!!
Posted 2011-05-10 6:10 PM (#134034 - in reply to #134025)
Subject: RE: Spare Tire Mount on a 99 Sooner
There should be a rod with a 90 degree bend in it.  The horizontal section is threaded.  The threaded end goes through the tire lug nut hole and a lug nut holds the tire to the trailer wall.  The verticle slot allows the rod to adjust to the tire.
Sounds like you're missing the rod.
Posted 2011-05-10 9:41 PM (#134046 - in reply to #134025)
You can find the threaded replacement rods at automotive wrecking yards. They hold the spare tire into the wheel well, and often are discarded when the car is scrapped. Look around for the matching lug nut that was removed when the spare was sold. It is usually thrown into the trunk area.
suhz88
Reg. Mar 2011
Posted 2011-05-11 1:55 PM (#134065 - in reply to #134025)
Thanks! I was kinda thinking maybe it was a set up like that but wasn't sure where to find the part. I'll check around.
