High Country Plastics 39 gal water tank straps
Last activity 2012-06-07 7:06 PM
4 replies, 10027 views
suhz88
Reg. Mar 2011
Posted 2012-05-30 6:53 PM (#144341)
Subject: High Country Plastics 39 gal water tank straps
I just bought the HCP 39 gallon corner tank and installed it in my trailer using the securing hardware they included with the tank. My first trip out the straps unwrapped and the tank fell over. Nothing like having 39 gallons of water in your tack room and a broken bridle rack where the tank landed. Needless to say, DON'T USE THE STRAPS THAT ARE INCLUDED WITH THE TANK. Buy some 1" ratchet straps and secure them with a D-ring BOLTED to the wall of your trailer.
Posted 2012-05-30 9:51 PM (#144352 - in reply to #144341)
Subject: RE: High Country Plastics 39 gal water tank straps
Thank you for the advice. I guess the original straps couldn't handle the ~300# weight. The after market ratchet straps should be more than enough.
I am considering the installation of the smaller 25 gal corner unit, and hadn't even considered the necessity of modifiying the OEM hardware.
Thanks again
acy
Reg. Oct 2006
Posted 2012-06-02 6:42 AM (#144427 - in reply to #144341)
I have 2 of those tanks on the hay rack.. great tanks but the flimsy little straps they send don't work.  I use kayak tie downs- 2 on each tank- and they hold fine.
gabz
Posted 2012-06-03 10:07 AM (#144470 - in reply to #144341)
1000100100100252525
I remember the instructions for my 48 gallon upright - it said to install retaining straps in addition to the web ones attached to the tank.
Was there any instruction sheet?
This is my second HCP water tank. My first was the saddle rack one. Sold that and got the 48 gal. half moon.  I use a 3" wide ratchet strap attached to 2 large rings that each have 2 screws holding them to the trailer wall. I built a base for my tank to get it off the floor and installed it where most trailers have a rear tack.
I'm dismayed at how badly the threads on the outlets hold up. Something on my bottom one is messed up and now it leaks all the time despite teflon tape, different faucet attachments, new washers, etc.  Only leaks when I get past about 15 gallons.  So I would advise ANYONE to put a faucet on and leave it on. I may have messed mine up when I remove the faucet for cleaning. Who knows.
mjkowboy
Reg. Feb 2012
Posted 2012-06-07 7:06 PM (#144649 - in reply to #144341)
I havent had any trouble and I travel a lot of bumpy gravel roads.  You have to make sure you get the straps tight and then tie a knot with the left over to prevent slipping. Also follow the instructions exactly as to where the straps should be in relationship to the height of the tank. Watch out for huge potholes though, I did dislodge my tank, full of water, 6 hours before we were heading to a big horse show...the wet tack room was nothing compared to 2 bent trailer axels. Never seen it coming in the dark while heading to fuel up
