Converting my weekender (Logan Competitor) I already put in foam board insulation but for the paneling do I screw into the ribs or how do I attach the paneling? ALSO does anyone know if I can cut out the corner shelves that are welded in? or are they structural?
Posted 2014-04-15 9:59 AM (#158659 - in reply to #158644) Subject: RE: DIY Conversion
Most owners will first affix furring strips to the wall studs, fill in between with insulation and then attach the inside surfaces to the wood strips. It is much easier than constantly drilling and screwing to the metallic wall structures. It also increases the available space for insulation.
Posted 2014-04-15 1:36 PM (#158666 - in reply to #158644) Subject: RE: DIY Conversion
What Gard said works best. You could also view some of the DIY projects in "albums" section. Here's mine showing 1x2 strips screwed in to the aluminum supportshttp://www.horsetrailerworld.com/forum/photos/show-album.asp?albumid=201¤tpos=10
