refrigerator won't cool on propane
Last activity 2014-07-24 8:28 AM
7 replies, 3868 views
4quartercirclesperfh
Reg. Jul 2014
Posted 2014-07-21 9:28 AM (#160045)
Subject: refrigerator won't cool on propane
It seems that when I switch over to propane my refrigerator doesn't seem to cool as good as shore power. I'm going to clean the burner off this weekend, I found in my paper work that in 08 my trailer had got a new refrigerator.
WSW
Reg. Jul 2014
Posted 2014-07-22 8:49 AM (#160067 - in reply to #160045)
Subject: RE: refrigerator won't cool on propane
make sure the trailer is level that is very important.i had the same problem.it also helps if the food is cool before you put it in the fridge.level is very important when running on propane.hope this helps.
beeoerdog
Reg. Jan 2014
Posted 2014-07-22 9:16 AM (#160068 - in reply to #160045)
10010010010025
Clean the flue as well
Reg. Jul 2014
Posted 2014-07-22 9:17 AM (#160069 - in reply to #160045)
What's the best way to level these trailers? I've stuck a torpedo level on the frame under the goose neck and lowered it till its level. Is there a better way?
WSW
Reg. Jul 2014
Posted 2014-07-22 1:09 PM (#160080 - in reply to #160045)
I HAVE WOODEN RAMPS MADE FROM A 2X10 WITH 12" OF STAGGER STACKED 3 HIGH THAT GIVE YOU ABOUT 5" OF RISE.USE ONE OR TWO TO LEVEL THE REAR THEN LEVEL THE FRONT WITH THE JACK.NOW YOU KNOW.
rockyrider
Reg. Jun 2004
Posted 2014-07-23 6:58 AM (#160089 - in reply to #160045)
100100100
I can usually level mine, front to back with just the trailer jack. Side to side I use wood blocks under the tires.
Reg. Jul 2014
Posted 2014-07-23 7:28 AM (#160090 - in reply to #160045)
Thanks guys for the most part were on shore power at horse shows and what have you but I guess I should have known being level was important so things flow.
Dunoir1
Posted 2014-07-24 8:28 AM (#160125 - in reply to #160045)
I turn mine on a few days before each trip to make sure it's good & cold before loading any food into it.  I'm in South Fla, so if it's hot outside, I find it just doesn't cool enough so I always bring coolers. Mine is the 3.0, so it doesn't switch over automatically.  If it's cold outside, I have to turn it down or the fridge part becomes a freezer.
