Do Brake Controllers Gradually Go Bad?
Jump to page : 1 2
Last activity 2015-06-22 2:51 PM
25 replies, 16751 views
beeoerdog
Reg. Jan 2014
Posted 2015-06-22 2:51 PM (#163839 - in reply to #160269)
Subject: RE: Sterling Coach OEM Marker Light Manufacturer
10010010010025
Some older controllers have an adjustment on them to "level" the sensor on the controller.....check that. Also, put a test light on the brake pin at the connector and manually operate the controller...the light should go from off to bright as you slide the switch on the controller.
Jump to page : 1 2
