The High Quality of Raymond Mill Manufacturers
Last activity 2014-09-17 9:35 PM
0 replies, 3650 views
lovestory
Reg. Sep 2014
Posted 2014-09-17 9:35 PM (#160803)
Subject: The High Quality of Raymond Mill Manufacturers
At present, the market is flooded with milling machine manufacturers large and small, too many to count, customers often see see things in a blur did not buyfor their own products. Not only delay the production, there are also likely tomiss the opportunity. While the Raymond mill is a mill equipment is currentlythe most common, the production of Raymond mill manufacturer is beyond count, each manufacturer has certain disparity in product quality and price.As Raymond Mill stable performance, strong adaptability, high performance price ratio, has been widely used in the milling process of barite, calcite,feldspar, talc, marble, limestone, dolomite, limestone, kaolin, bentonite,cement, gypsum and other inflammable and explosive mineral, chemical,construction and other industries more than 280 kinds of materials. With the wide development of non metallic minerals in ultrafine powder application domain, the downstream enterprises of non metallic mineral products of the increasingly high demand. Especially, there are more requirements on the product fineness. This makes the traditional Raymond mill not be available.Advantages of Raymond Mill1, Raymond mill host transmission device adopts closed gearbox and belt wheel, transmission smooth, reliable operation.2 important parts, Raymond mill adopts high-quality castings and extrusionsmanufacturing, fine craft, rigorous process, to ensure the durability of the whole set of equipment.3, the electrical system adopts centralized control, mill shop basicallyunmanned homework, and repair.4, the Raymond mill is a vertical structure, covers an area of relatively small,systematic, whether from the rough machining is raw material to delivery to themilling and the final packaging, can be as an independent production system.5, Raymond mill and other grinding equipment relatively speaking, it's a high rate of pass through screening, screening rate 99%, other milling equipment isgenerally not of the.We engaged in the research and development of professional equipmentmanufacturing mill, Raymond mill is through the authority of experts research update Raymond Mill further improved, compared with the traditional Raymond mill, its structure has been increasingly perfect, has the advantages of high efficiency, low energy consumption, small occupation area, less capital investment and no pollution to the environment. Raymond mill system is strong, through screening rate high, composition of powder finenessuniformity, through screening rate reached 99%; smooth transmission, high abrasion resistance, the core components are the use of wear-resistant materials of high performance, high abrasion resistance, saving the cost; easy control, convenient maintenance, by electrical and gas system with centralized control, the use of electromagnetic vibrating feeder feeding, continuous and uniform, easy adjustment, fuel saving, convenient maintenance.Raymond mill: http://www.raymond-mill.net/
