Charging 120
Last activity 2014-10-14 7:13 AM
5 replies, 3762 views
Latts55
Reg. Feb 2014
Posted 2014-10-13 4:37 PM (#161134)
Subject: Charging 120
having problems with charging when plugged into 110 my lights don't work and battery won't charge
beeoerdog
Reg. Jan 2014
Posted 2014-10-13 4:50 PM (#161135 - in reply to #161134)
Subject: RE: Charging 120
10010010010025
Check the fuses on your converter. Also check the circuit breakers in the trailer. Also verify that the outlet you are plugged into is working.
Latts55
Reg. Feb 2014
Posted 2014-10-13 5:50 PM (#161136 - in reply to #161134)
All the plug ins work and it keeps blowing the fuse Tks
beeoerdog
Reg. Jan 2014
Posted 2014-10-13 6:19 PM (#161137 - in reply to #161134)
10010010010025
How old is battery? Disconnect from trailer and try charging with a separate battery charger. The battery could be shorted out internally causing the fuses to blow. With the battery disconnected, see if the fuses blow
Posted 2014-10-13 10:25 PM (#161140 - in reply to #161134)
Has the battery (s) been removed and replaced? Are the leads in the correct polarity? Most converters have fused polarity circuit protection.
Latts55
Reg. Feb 2014
Posted 2014-10-14 7:13 AM (#161143 - in reply to #161134)
Thanks for all your replays. The place had had service done hooked up the battery wrong,working fine now
