Would someone more experienced then I mind taking a look at these photos? Considering trade our trailer straight up for this one (even swap) but we are getting rid of a high quality 4Star 4Horse and I don't want to end up with a piece of junk. Open to any opinions, suggestions, etc. thanks!
Posted 2014-11-18 12:15 PM (#161648 - in reply to #161623) Subject: RE: 2006 Sundowner 777 - floor pics
I would suggest removing the SunCoating that you see on the floor. That can usually be easily done by cutting it where the wall/floor join, and then pull it up as a sheet. Once done, you can see the actual aluminum floor. We often find, that urine has gotten trapped under the coating, and corroded the floor.
I might suggest a close inspection underneath as well.
Posted 2014-11-20 8:49 AM (#161692 - in reply to #161623) Subject: RE: 2006 Sundowner 777 - floor pics
I had a '04 Sundowner that had quarter size holes under the sun coating sheet. I always cleaned trailer out after I used it but the urine gets trapped under the suncoating. Mine had a 8 year warranty on it so Sundowner replaced the entire floor. My frame remained in good shape, however. I have purchased a '03 Sundowner and had no problems with this floor but it is all aluminum and had no suncoating on the floor.
