Posted 2015-03-05 2:30 PM (#162764) Subject: Replacing a switch on ’07 Silverlite
I suspect my light switch needs to be replaced. I was able to do it on every other trailer I’ve had (4 Stars and Platimum), but I can’t figure out how to get into this one. It’s located at the back of the trailer, on the outside, like every other one of seen. I haven’t been able to find any other way to access this area. There’s no access from the inside of the rear tack, and no access from any nearby lights (ie, pull out a tail light to get to the back of the light switches. My older 4-Star was like that).Is that a rivet, or do I need the world’s smallest allen wrench (photos attached)?Seems odd to make it so permanent that I would need to drill out the rivets, and re-rivet, just to change a switch….Any ideas?
Posted 2015-03-05 5:27 PM (#162767 - in reply to #162764) Subject: RE: Replacing a switch on ’07 Silverlite
Thanks you guys! But doesn't it seem insane to rivet-in something that needs to be accessed somewhat frequently? For whatever reason these switches never seem to last very long.It might not be a bad idea either to replace both of them while I'm in there.....right?
Posted 2015-03-05 6:09 PM (#162768 - in reply to #162764) Subject: RE: Replacing a switch on ’07 Silverlite
Also, might not be the switch...check contacts at light fixture....doesn't take much corrosion to stop 12 volts. If you change the switch, put in a good one rated for 12 volts.
Posted 2015-03-05 9:20 PM (#162769 - in reply to #162764) Subject: RE: Replacing a switch on ’07 Silverlite
Installing switches from a marine or aircraft supply, will result in a longer life span of the switches. These switches are sealed from the elements, and have commercial grade interior constructions. Many of these will last longer than the ownership of the trailer. Also, by using marine quality, waterproof blind rivets, you will eliminate water seepage from the exterior elements into the interior locations of the switches. The waterproof rivets have sealed core ends instead of the open ended shafts that are commonly used.
Posted 2015-03-05 9:59 PM (#162770 - in reply to #162764) Subject: RE: Replacing a switch on ’07 Silverlite
I live in a pretty small town.....but we do have a Napa. Do you think Napa would have marine-grade switches? Or a True Value? Or do I need to find a marine supply place online?
Posted 2015-03-06 7:05 AM (#162777 - in reply to #162764) Subject: RE: Replacing a switch on ’07 Silverlite
I have brought mine back to life many times by flooding it with WD-40 while I was toggling the lever. The WD-40 will displace the moisture in the switch. May try that before replacement.
Also- most NAPAs etc will have a rubber cup you can buy that screws over the switch for some protection.
