Anyone ever tried with success in removing lots of halter scratches on aluminum fenders? If so what would be the process? New to me Featherlite with lot's of scratches on fenders...some kinda deep. Can I make these look like new and how?Thank you
Posted 2015-03-27 9:13 PM (#163032 - in reply to #163027) Subject: RE: Scratch removal on aluminum fenders?
If the scratches are deep, they can be partially filled by burnishing the metal. This involves rubbing a smooth hardened steel instrument over the affected area, whilst being lubricated by a light weight oil. If the areas are on a curve, a round screwdriver shaft and motor oil can be used. If it's a flat surface, a body dolly will help. Burnishing will physically move the metal from high to low areas, without removing the base aluminum. If the scratches are very deep, sanding the metal will weaken the surrounding areas. Fill the scratches with a compatible welding rod, and then sand and polish the surfaces smooth. Using steel wool to polish aluminum, will result in small particles to become imbedded in the aluminum, and when exposed to the elements, cause rusting and surface discolourations.
Posted 2015-03-28 3:31 AM (#163033 - in reply to #163027) Subject: RE: Scratch removal on aluminum fenders?
And..... Sometimes it's best to leave well enough alone, the more you try to make it look better the more obvious it becomes. Whatever you decide to do to that fender probably needs to be done to the second fender also if you want them to match or look near the same.
Posted 2015-03-28 1:22 PM (#163035 - in reply to #163027) Subject: RE: Scratch removal on aluminum fenders?
If the scratches are deep enough...one your trailer is personalized...two a little less likely to be stolen...three identifiable by the scratches if it is stolen...
