Don't laugh but what's the easiest way to hook up a
Last activity 2015-06-22 4:24 PM
18 replies, 11543 views
acy
Reg. Oct 2006
Posted 2015-04-15 10:18 AM (#163165)
Subject: Don't laugh but what's the easiest way to hook up a
gooseneck with a crew cab truck? My old truck had a crew cab and I could just turn around and see the ball.
All suggestions appreciated- thanks!
postlewaitee
Reg. Jul 2014
Posted 2015-04-15 10:57 AM (#163166 - in reply to #163165)
Subject: RE: Don't laugh but what's the easiest way to hook up a
you could install a camera against the cab of the truck and use it when backing up to the trailer (my friend has this), or a tennis ball on a stand and use it to guide you (my inlaws use this method), or get a friend to help you. i'm 5' and have a hard time turning around and seeing the ball from inside the truck (i have a mega cab). all i do is try to get the truck and trailer lined up the best i can and back up to where i think the ball is and get out to look then adjust accordingly. I can usually get it the second try. The more you do it the better you will be at it, you will eventually get use to it and it will become easier and easier. Good luck!
ThreeCW
Reg. Apr 2014
Posted 2015-04-15 12:55 PM (#163167 - in reply to #163165)
Check out this earlier discussion:
http://www.horsetrailerworld.com/forum/thread-view.asp?threadid=197...
gonzo1066
Reg. Oct 2010
Posted 2015-04-15 6:31 PM (#163168 - in reply to #163165)
I painted a bright color stripe down the center of the truck bed, I can see the stripe out the rear window of the truck but not the ball. I installed a convex mirror on the front of the trailer so I can see the ball. Works for me.
Posted 2015-04-15 7:33 PM (#163170 - in reply to #163165)
When I teach people to get the feel of hitching up...I use one of these for training...stick the camera on the gooseneck pointing straight downward and place a firring strip in the bed in a line from the rear of the folded-down tailgate to the ball hitch...people seem to pick up the techniques of hooking up their truck and trailer in a rather short period of time...:) http://www.etrailer.com/Backup-Cameras-and-Alarms/Swift-Hitch/04928...
dbrown
Reg. Oct 2013
Posted 2015-04-16 6:04 AM (#163174 - in reply to #163165)
Get one of those magnetized key boxes and take apart leaving just the magnet. glue a piece of wood to the magnet with a hole drilled in it for a length of dowel. Insert dowel into piece of wood. Place the magnet on top of the ball. Back up to the trailer and when the dowel moves you are lined up. Stop and let down the trailer.
acy
Reg. Oct 2006
Posted 2015-04-16 7:03 AM (#163175 - in reply to #163165)
Great answers- thanks so much everyone!
Three 4 Luck
Posted 2015-04-16 7:46 AM (#163176 - in reply to #163165)
I line up the hitch with the center of the tail gate, back straight from there until it looks like the tail gate is super close to the trailer, then get out and look. Usually I heed to go back 2-3 more inches.
Shari
Posted 2015-04-17 10:22 AM (#163184 - in reply to #163165)
I saw someone said they put one of those pool noodles over the ball so it stands up. I haven't tried it yet.
cutter99
Reg. Sep 2007
Posted 2015-04-17 6:13 PM (#163186 - in reply to #163165)
10010010010025
A toilet plunger set between the gooseneck ball and cab if the truck works well as a guide.
flatlandfilly
Reg. Jun 2006
Posted 2015-04-18 6:00 PM (#163191 - in reply to #163165)
I stretch a bungee cord across the pickup bed so it is above the ball. Then tie another bungee cord right over the ball. I back up until gooseneck hitch reaches the knotted bungee cord then get out to check. I may have read about the strategy on this web site.
I used this method after spending money on a stick with a magnetized base. It was supposed to stick to the ball and stand tall enough to be seen to facilitate getting the trailer hitched. It was a waste of money. The magnet was so flimsy the thing would fall over when I started backing up.
AZgrulla
Reg. Jan 2009
Posted 2015-04-19 6:13 AM (#163195 - in reply to #163165)
Install a flatbed...very easy to see the ball!!!
z71ton
Reg. Jun 2011
Posted 2015-06-07 7:21 AM (#163667 - in reply to #163165)
headhunter
Reg. Oct 2004
Posted 2015-06-08 11:53 AM (#163676 - in reply to #163165)
50010010025
Ditto on the bungee cord over the ball method.
horsey1
Reg. Dec 2004
Posted 2015-06-08 12:25 PM (#163678 - in reply to #163195)
Originally written by AZgrulla on 2015-04-19 6:13 AM
I thought that was Paul's line! :)
Posted 2015-06-08 2:42 PM (#163681 - in reply to #163678)
Originally written by horsey1 on 2015-06-08 12:25 PM
Originally written by AZgrulla on 2015-04-19 6:13 AMInstall a flatbed...very easy to see the ball!!!
Ah...it's becoming a movement...:)
Mike Palmer
Reg. Jan 2014
Posted 2015-06-11 3:21 PM (#163748 - in reply to #163165)
Automotive telescoping magnet on the ball. Follow till it falls over. Lower trailer.
scottc79
Reg. Aug 2013
Posted 2015-06-19 12:36 PM (#163816 - in reply to #163165)
I bought one of these at harbor freight and it works great I put in just behind the ball in the bed and raise it up so I can see it and when the ball touches the goose neck I stop and lower the truck down on the money every time http://www.homedepot.com/p/Reese-Towpower-Steel-Solo-Hitch-7012900/...
bjhouten
Posted 2015-06-22 4:24 PM (#163840 - in reply to #163165)
5002525
I got a plastic fish eye and put it on my rear window. (Pep Boys $10) It worked great. I could see the ball and hitch. When we put a above rail tool box in the bed it no longer worked because the tool box got in the way. I now have a truck with the bed camera mounted on the top of the cab and that works really well. But the fish eye was cheaper. :-)
