Anyone towing goose neck with tool box in bed of pickup?
Last activity 2015-04-27 6:19 PM
7 replies, 4012 views
g-dog
Reg. Mar 2014
Posted 2015-04-25 7:53 PM (#163261)
Subject: Anyone towing goose neck with tool box in bed of pickup?
I am wondering if it is advisable to pull living quarters horse trailer with a drop in toolbox? It does sit on the side rails and it is probably six inches on top of bed rails. I haven't pulled or even hooked up to trailer yet? I know a tool that sits between rails would be no problem...just not sure about the boxes that sit on top of rails.Thank you
beeoerdog
Reg. Jan 2014
Posted 2015-04-26 8:36 PM (#163266 - in reply to #163261)
Subject: RE: Anyone towing goose neck with tool box in bed of pickup?
10010010010025
Bad idea....usually there barely enough room without a box sticking up
Miner
Reg. Jul 2009
Posted 2015-04-27 8:05 AM (#163276 - in reply to #163261)
We have a Dodge dually with a standard box and we do not have a problem.  Plenty of room.
Posted 2015-04-27 8:30 AM (#163277 - in reply to #163261)
A friend of ours with a Ford has no problem pulling his GN trailer with the box installed. Plenty of room in front of the GN, with no interference issues.
Spin Doctor
Reg. Nov 2008
Posted 2015-04-27 2:34 PM (#163279 - in reply to #163261)
Is the box going to be in front or behind the ball?
In front, you lose some visibilities when hooking/unhooking, but other than that, I see no problems. I would recommend at least ~6" of clearance between the ball and the box (more is better of course).
Behind the hitch can lead to clearance issues and the difficulties of moving to hook and unhook trailer. Have seen it done on rigs that seldom are disconnected.
Good luck!
skippyvcu
Reg. May 2006
Posted 2015-04-27 2:56 PM (#163280 - in reply to #163261)
Not a question that can be answered without seeing your rig. It all depends on how much clearance you have between the bed rails and the bottom of the gooseneck. Hook up the trailer, get it adjusted so that it is riding level and see how much clearance you have. Is it enough to allow for sharp backing angles on whatever grades you expect to encounter? With our truck and trailer, we would be to close for my comfort.
Posted 2015-04-27 4:27 PM (#163284 - in reply to #163261)
Originally written by g-dog on 2015-04-25 7:53 PM
Well, if you approach the 90 degree position relative to your trailer you may discover that you will have contact between the toolbox and the trailer's side...
g-dog
Reg. Mar 2014
Posted 2015-04-27 6:19 PM (#163285 - in reply to #163261)
Thanks everyone for your responses!
