Smoking breaks help needed
Last activity 2015-07-30 9:15 PM
4 replies, 3552 views
Joemac8
Reg. Mar 2013
Posted 2015-07-30 7:27 PM (#164300)
Subject: Smoking breaks help needed
I have a Featherlite 9407 dual horse trailer that is two years old with less than a thousand miles. The trailer has electric breaks. I don't actually have the trailer, my daughter who is away at school 350 miles away has the trailer.
She is moving between apartments at school and has furniture in the trailer for the move. Prior to this, the trailer has sat at the stable for 9 months.
She had a friend with a Chevy Avalanche move the trailer about three miles. When they arrived, she saw a small black plastic box which is attached on top of the trailer tongue, was smoking. I assume this is a control for the brake???
I know zip about trailers. She wants to move the trailer to the new apartment but I told her not to move it as smoking boxes cannot be good.
Any ideas of what this might be?
beeoerdog
Reg. Jan 2014
Posted 2015-07-30 8:22 PM (#164301 - in reply to #164300)
Subject: smoking
10010010010025
Sounds like the breakaway switch..Google that and you can see what it looks like. If it is smoking, the lanyard holding the key in the switch may have been pulled thereby activating the electric brakes....not a good thing.
Posted 2015-07-30 8:24 PM (#164302 - in reply to #164300)
Subject: RE: Smoking breaks help needed
It sounds as if the emergency brake's tether was pulled, or the hot lead from the battery inside, is inadvertenly grounded. The tether can be reinserted into the switch, but by now the battery will be dead and you won't notice any difference. This situation should be resolved before any livestock is hauled on the open road. Moving furniture around town shouldn't be a problem. This emergency braking system is only used if your hitch fails, then the safety chains also fail, leaving only the electric brakes as a last resort to stop an errant trailer from rolling down the road.
Posted 2015-07-30 9:09 PM (#164303 - in reply to #164300)
My first thought is a malfunctioning breakaway battery charger.
Posted 2015-07-30 9:15 PM (#164304 - in reply to #164300)
Replace it with one of these...:) http://www.etrailer.com/Trailer-Breakaway-Kit/Hopkins/20099.html
