Trailer wiring
Last activity 2015-08-02 7:35 AM
2 replies, 3081 views
Wpage01
Reg. Aug 2015
Posted 2015-08-01 2:48 PM (#164326)
Subject: Trailer wiring
Ford 150 not sensing trailer. Has brake controller. Have brake, running and tuen lights but no interior lights or fans. Trailer is a 2000 star lite 2h bp. The vehicle is new to this trailer. Have checked all fuses, all relays, etc. any suggestions?
beeoerdog
Reg. Jan 2014
Posted 2015-08-01 4:18 PM (#164327 - in reply to #164326)
Subject: lights
10010010010025
Try with ignition key turned on....if it still doesn't work, check trailer wiring section at bottom of HTW home page and verify proper operation of vehicle (12v +) at proper pin position....did the lights work with previous vehicle....if so, the wiring may be different and you just need to sort it out. Get yourself a test light and verify that each pin is doing what it is supposed to be doing.
Posted 2015-08-02 7:35 AM (#164336 - in reply to #164326)
Subject: RE: Trailer wiring
Originally written by Wpage01 on 2015-08-01 2:48 PM
Determine if you are getting power at the truck pin as shown in these diagrams... http://www.etrailer.com/faq-wiring.aspx
