Help! Headliner sagging: Is there any way to get it to stick back up?
Last activity 2015-08-26 5:09 AM
3 replies, 3830 views
g-dog
Reg. Mar 2014
Posted 2015-08-25 8:06 PM (#164536)
Subject: Help! Headliner sagging: Is there any way to get it to stick back up?
Have a 2001 living quarters horse trailer...the ceiling ( head liner ) is starting to sag in places. A few areas that are 9-12 square inches. Is there a way to get these areas back up where they belong? Don't want the weight of these areas to create more sagging. There has to be a way to do this without pulling the whole thing down and starting over?Thank you
Posted 2015-08-25 8:15 PM (#164537 - in reply to #164536)
Subject: RE: Help! Headliner sagging: Is there any way to get it to stick back up?
Depending upon the material, a small slit can be created with a razor knife, and 3m spray adhesive can be inserted using a small diameter tube in the spray head. Support the effected area and usually the glue will hold in a few minutes. If it's fabric, the sagging area may have stretched a bit and it's difficult to eliminate all the wrinkles. If it's a rigid covering, a small diameter drill bit can be utilized to penetrate the surface. If there are many delaminations, it's better to remove the liner and start over.
g-dog
Reg. Mar 2014
Posted 2015-08-25 8:23 PM (#164538 - in reply to #164536)
Thanks Gard...it is fabric. I will try the adhesive.
hornet
Posted 2015-08-26 5:09 AM (#164540 - in reply to #164536)
My first car in high school did this. I took thumb tacks and made the pillow top look.
