Posted 2015-08-31 3:16 PM (#164579) Subject: Breaking in my new diesel, rules?
OK, I've gone and done it and the new truck gets here Friday. My last diesel was the legendary 7.3L Powerstroke, this one is the 2015 6.7L Ford diesel engine. Back when I bought my last one it seems to me there were "rules" about breaking the engine in like not using the cruise control during the first so-many miles so it wouldn't burn in a sweet spot (or something like that.) Is there any advice on the new ones? Any helpful tips for a former diesel owner that has changed in the last 8 years or so? I remember when you changed the oil every 3,000 miles even when they moved the interval up to 5,000 miles...Gosh I'm getting old but now I can afford my toys!
Posted 2015-09-01 6:40 AM (#164583 - in reply to #164579) Subject: RE: Breaking in my new diesel, rules?
The owner's manual will describe the first operational mileage for your new truck. Our initial usage was restricted from pulling trailers for a time, until a certain amount of mileage was achieved. ( can't remember the exact amount) After the first oil change, we switched to synthetic oil and have run it ever since. Once the warranty period expired, we extended the oil change intervals to 7500-10K miles whilst using the synthetic products. Having owned a diesel, you're aware of the heat soaking after long pulls, and the necessary cool down cycles following hard usages. I was taught this basic rule many years ago and it's still apropos today, especially with the proliferation of turbo installations. "Don't run a diesel when its cold, don't put it away hot." Enjoy your new truck and all the improvements the new models offer.
Posted 2015-09-01 7:03 AM (#164585 - in reply to #164579) Subject: RE: Breaking in my new diesel, rules?
This is what I did with my 2012 6.7, not sure if it matches the owner's manual or not. I put a few hundred miles on it before dragging the trailer. I varied the speed +/-5 while pulling for the first trip. After that, I drive it like I stole it. I do know that it has beak in oil and it needs to be run it entire period or the engine will tick like a type writer. Now for some advice, I have been told by several and now passing along to you. Only use Motorcraft filters. Ford has not released the patents so the aftermarket are not the same. They will fit and filter, but they do not provide the same back pressure for or hold the pressure on the fuel system. Ford will not tell you that you cannot use them.
Posted 2015-09-01 6:00 PM (#164590 - in reply to #164579) Subject: RE: Breaking in my new diesel, rules?
13 6.7 had 10 miles on it when we hooked about 16,000# of 4h LQ on it. Has 60k on it of which 57k were pulling that trailer. Cool feature that comes with the truck, or at least ours, is you can track your trailer pulling mileage in the info center. Serviced every 5k by Ford. So far it's been great! Breakin was normal driving with trailer to answer your question. Idling these new trucks is not a good idea in my opinion. We limit idle to a minute or less when possible. Just my opinion.
