Ramp latch not going low enough - catches
Jump to page :
Last activity 2015-10-07 8:53 PM
4 replies, 4179 views
View previous thread
View next thread
General Discussion
Trailer Talk
Click to return to Barrel Talk
Flat
Threaded
Nested
LEAshoot
Reg. Oct 2015
Posted
2015-10-05 6:07 PM (#164968)
Subject:
I have a sundowner with a ramp. The latch won't go down low enough to go under the catch. I don't see a way to get to the latch without drilling out all the rivets. Any quick fixes? TIA!
huntseat
Posted
2015-10-05 6:16 PM (#164970 - in reply to #164968)
Subject:
RE: Ramp latch not going low enough - catches
pictures?
Posted
2015-10-05 8:14 PM (#164971 - in reply to #164968)
Subject:
Is your setup like this?
http://distillery-trailercentral.s3.amazonaws.com/FWJwsK/jXsiWW/201...
If so, is it the bar that is attached to the ramp? And if that is the case, is your latch lever been bent recently?
RTSmith
Posted
2015-10-06 10:12 AM (#164977 - in reply to #164968)
Subject:
If the latch has a fair amount of movement, you need to see about moving the loop up. That should be only 1 bolt in the door, easy to get to.
The latches seldom give issues.
Posted
2015-10-07 8:53 PM (#165000 - in reply to #164968)
Subject:
Check the mounting bolts on the hinge And the hinge itself... Seems if they got loose, the ramp would drop, leading to your problem.
Jump to page :
General Discussion
+ Trailer Talk
+ Camp & Trail
+ Horse Talk
Flat
Threaded
Nested
View next thread
