No lights in bathroom.
Last activity 2016-05-10 2:30 PM
6 replies, 3242 views
riverrat
Reg. Mar 2016
Posted 2016-05-09 9:16 PM (#167033)
Subject: No lights in bathroom.
I have a 2013 Bison trailer that the lights don't work in the bathroom. The electrical outlet works just no lights. Fuses are good and so are the light bulbs. Any ideas on the problem?
beeoerdog
Reg. Jan 2014
Posted 2016-05-09 10:02 PM (#167034 - in reply to #167033)
Subject: RE: No lights in bathroom.
10010010010025
The lights are 12vdc...is your battery charged?....outlet is 120vac
Posted 2016-05-10 1:14 AM (#167036 - in reply to #167033)
Have they ever worked?
riverrat
Reg. Mar 2016
Posted 2016-05-10 7:32 AM (#167039 - in reply to #167033)
All the other lights work just fine. And the lights in the midtack works so it's got to be right there in the bathroom. Thanks for advice.
beeoerdog
Reg. Jan 2014
Posted 2016-05-10 10:00 AM (#167040 - in reply to #167033)
10010010010025
Get a 12v test light and check for voltage on each side of switch
RustyScupper
Reg. Mar 2013
Posted 2016-05-10 2:14 PM (#167045 - in reply to #167033)
Bathrooms have a lot of condensation if fan isn't used when showering. Check for corrosion in the bulb socket. Measure voltage in the socket to make sure you have 12v to the socket.
riverrat
Reg. Mar 2016
Posted 2016-05-10 2:30 PM (#167046 - in reply to #167033)
Found the problem! Big thank you to Brady Clark! He found that where the electrical wires go into the fuse panel box the wire wasn't stripped enough that it was shorting out but not enough to blow the fuse. There was two of them like that. Signature Quarters ROCKS!!!!!
