clogged shower drain
Last activity 2016-05-26 10:56 PM
2 replies, 2792 views
northernmom
Reg. Jan 2011
Posted 2016-05-26 7:59 PM (#167156)
Subject: clogged shower drain
The shower drain is clogged, I've worked at it w/a plunger several times and each time it will drain for a few seconds then stop again. Is it safe to use commercial drain opener chemical products in that shower drain, or what else can I do? Thanks!
huntseat
Posted 2016-05-26 9:06 PM (#167157 - in reply to #167156)
Subject: RE: clogged shower drain
1000500100100100100252525
Have you visually inspected the underside of the drain opening into the tank? Are the tanks drained?
Posted 2016-05-26 10:56 PM (#167158 - in reply to #167156)
You can purchase an inexpensive "snake" at most home and hardware stores. If you can get the cover plate off the drain, you will usually find hair and other contaminates clogging the drain. A bent hook made of wire, can be used to extract most of the visible materials. Any liquid drain cleaner you try to use, should be specifically made for plastic pipes.
