Circle J wheel bearings
Last activity 2016-07-22 9:05 AM
5 replies, 3926 views
di-ski
Reg. Jul 2016
Posted 2016-07-21 7:36 PM (#167765)
Subject: Circle J wheel bearings
Good Evening,We have an older Circle J straight load, mangers, ramp, etc. It is a 1989. Oldie but a goodie. How do we go about finding wheel bearings for it? Just pull a wheel, take it to the auto parts store and order 4 or is there a place to order for this trailer on line? We want to make sure we get the right ones. Thank you and our horses thank you as well.
beeoerdog
Reg. Jan 2014
Posted 2016-07-21 7:39 PM (#167766 - in reply to #167765)
Subject: RE: Circle J wheel bearings
10010010010025
check the axles for a identification tag. The races and bearings will also have numbers etched into the edges.
di-ski
Reg. Jul 2016
Posted 2016-07-21 7:45 PM (#167767 - in reply to #167766)
thank you.
Dbarnes72
Reg. Dec 2015
Posted 2016-07-21 8:59 PM (#167768 - in reply to #167765)
Take a seal with you too. Often there is a part number on the seal. If not, a parts store employee should be able to match it up based on ID and OD.
di-ski
Reg. Jul 2016
Posted 2016-07-22 7:05 AM (#167771 - in reply to #167768)
Appreciate your help. thank you.
Posted 2016-07-22 9:05 AM (#167772 - in reply to #167765)
Do not purchase the least expensive bearings at your auto parts store. At a slightly higher pricing, you can find several brand names that are available and are direct replacements. The bearings can easily be be matched by size, and the part numbers are stamped on the bearings' hubs. Replace the races at the same time the bearings are renewed. Make sure to the set the initial torque, and if you can, retorque them about a thousands miles later. Packed with synthetic grease, these new bearing can last as long as your ownership of the trailer.
