Place to get butt bars and hardwear?
Last activity 2014-07-16 8:12 PM
6 replies, 3396 views
BILLYS
Reg. Apr 2014
Posted 2014-07-16 2:11 PM (#159932)
Subject: Place to get butt bars and hardwear?
Me again. Little girl would like to put in a butt bar. Just looking for a place that has them. I understand how they work, just having a hard time picturing the mounting process. Thanks for looking.
BILLYS
Reg. Apr 2014
Posted 2014-07-16 2:12 PM (#159933 - in reply to #159932)
Subject: RE: Place to get butt bars and hardwear?
PS. If it matters, its a 3H goose neck Classic 2002
diggerdoo
Reg. Oct 2009
Posted 2014-07-16 2:38 PM (#159934 - in reply to #159932)
We have ordered stuff from here:
http://www.sundownerparts.com/.sc/ms/cat/Trailer%20Body%20Components--Breast%20%26%20Butt%20Bars
This is from the Sundowner page, but it looks like they supply parts for other kinds, too.
BILLYS
Reg. Apr 2014
Posted 2014-07-16 3:59 PM (#159935 - in reply to #159932)
Thank you. I have seen that page... My question on that bar is, I guess you drill a hole at the intersection of the "V" in the white delron part for the pin??? Then how does the loop on the bar attach? With a "S" hook maybe to the C shaped bracket?
Posted 2014-07-16 6:42 PM (#159936 - in reply to #159932)
http://www.horsetraileraccessorystore.com/trailer_butt_chains.htm
PDGx
Reg. Jul 2011
Posted 2014-07-16 7:44 PM (#159938 - in reply to #159932)
You are correct on the Sundowner bar the plastic V is just a guide to help align the spring loaded pin on the bar when positioning the bar across the stall. It's attached with the 4 rivets since it doesn't actually hold anything. The loop on the other end of the bar is mounted directly by the C bracket so there is no slop in the bar across the opening. Just make sure the dimension of the bar is correct for your stall width before ordering.
BILLYS
Reg. Apr 2014
Posted 2014-07-16 8:12 PM (#159939 - in reply to #159938)
Originally written by PDGx on 2014-07-16 7:44 PM
AHHH ,got it. For some reason I was thinking the whole thing was removable. The "C" thing is stationary. Don't know why I could not see that in my mind.... Thank you.
