looking at getting a 2005 bloomer 3 horse living quarter trailer. the outside needs a good pressure washing but the inside is fantastic.the decals are peeling in places and wonder if anyone has any experience in removing them and replacing them with new ones if they are available from the manufacturer.
also wondering if it is worth it to replace the rear mats with that worm coating for better protection of the floors. Presently the floors look fine as they are.
Posted 2015-05-26 8:18 AM (#163546 - in reply to #163537) Subject: RE: decals
when i removed the decals from my old trailer i used a heat gun (you could use a hair dryer) to warm the glue and they peeled right off. any extra goo left can be removed with goo gone or any other adhesive remover. the paint will more than likely be a different shade or color than the rest of the trailer since it hasn't been exposed to the elements, not much you can do about that unless you paint the whole thing.
as far as new decals you can get them from the dealer or order them online. good luck!
Posted 2015-05-27 10:44 AM (#163553 - in reply to #163537) Subject: RE: decals
You should be able to get replacement decals right from Bloomer. Most graphic design places will recreate them as well. If Bloomer doesn't have them or you can't find a good company locally for some reason give us a call and I can put you in contact with the company we use. Thad
