LQ Shower question
Last activity 2015-09-23 8:13 PM
3 replies, 3335 views
Jordan84
Reg. Jul 2010
Posted 2015-09-23 4:13 PM (#164807)
Subject: LQ Shower question
This weekend we noticed a small leak coming from our shower, so I'm trying to open up the bottom to investigate but I think I'm missing something. How do you pull the panel off to get to the plumbing under the shower? I'm afraid that I'm going to break something since its plastic. I'll try to attach a picture of what I'm talking about.
Jordan84
Reg. Jul 2010
Posted 2015-09-23 4:28 PM (#164808 - in reply to #164807)
Subject: RE: LQ Shower question
PDGx
Reg. Jul 2011
Posted 2015-09-23 7:14 PM (#164809 - in reply to #164807)
Those two white buttons are obviously your access to remove the plate. However the pic is not focused well enough to tell if they have a 2-part head. If there looks like there is line or gap around the head, try to separate it with a knife and pull it out, which should then release the remaining part. If it is this type, it will have a pin attached that goes into the part against the shower. If there is no gap, slide a knife right under the head against the shower, and see if it will retract.
Jordan84
Reg. Jul 2010
Posted 2015-09-23 8:13 PM (#164811 - in reply to #164809)
Thank you!! I knew it had to be something simple that I was overlooking. I wanted to yank on the tabs with pliers but I figured I'd check here first. Used the knife like you said and they popped right off, they were just covers over a screw. I feel like such a blonde now
