Horse trailer affect truck payload?
Last activity 2016-02-11 11:06 AM
3 replies, 2879 views
shannon1066
Reg. Feb 2016
Posted 2016-02-10 8:34 PM (#166093)
Subject: Horse trailer affect truck payload?
I am looking for a truck camper to use when pulling horses. When hauling horses how does that affect your truck's payload? I have a 2016 Chevrolet Silverado 2500HD 6.6 bed, with a payload of 3500. When looking at the dry weight of a camper, what weight should I stay under? I was told to minus 1000lbs so that would mean a camper under 2500 pounds. First, is that accurate? There is a camper I would like to have that is 2900 pounds dry. When hauling horses do I need to subtract the horse trailer tongue weight? My towing limit is 14,800 and I'm hauling 6,000 with the trailer and horses. Thanks. I am so confused with all of this and certainly do not want to be unsafe. Thank you.
Posted 2016-02-10 10:34 PM (#166094 - in reply to #166093)
Subject: RE: Horse trailer affect truck payload?
If your proposed camper weighs 2900# dry, you can easily expect the necessary fluids and gear to weigh an additional 500# or more. This will place you at or over your truck's max 3500# carrying capability. This will leave nothing for the trailer's tongue weight. You will need to find a camper, that when grossed out, weighs ~2K or less. This will give you some capacity to haul the trailer, which can have a tongue weight of 1K or so, when it's loaded. Adding suspension aids will not increase the capacity of the truck's rear axle or tire capacities.
horsey1
Reg. Dec 2004
Posted 2016-02-11 10:36 AM (#166101 - in reply to #166093)
Rhetorical question here- what affect would a weight distribution hitch have in this scenario? As it can transfer a large amount of the weight to the front axle of the truck? I truly don't know, but as close as those numbers are, and with a BP carrying about 10% tongue weight anyway- might that shift make it all work?Would certainly add a ton of stability/safety to the equation as well.
Posted 2016-02-11 11:06 AM (#166102 - in reply to #166093)
Your other problem is that most campers will require a special bumper hitch which will FURTHER REDUCE your tongue capacity...
