Center caps on Sundowner ??
Last activity 2005-07-11 9:54 AM
2 replies, 3788 views
DuallyNewt
Reg. Sep 2004
Posted 2005-07-09 1:03 PM (#27834)
Subject: Center caps on Sundowner ??
Does anyone have any ideas on keeping the center caps from flying off , I have tried caulk on the lugnuts.? So far I have lost 2..Thanks
Posted 2005-07-09 11:31 PM (#27857 - in reply to #27834)
Subject: RE: Center caps on Sundowner ??
Never had this problem.  But a few thoughts on yours..
You might check the wheel balance, if the wheel was out of balance, the eccentric forces will loosen the cap's grip.  Check the tire tread, if you see cupping of the tread, it's definitely out of balance and is "bouncing" on the road.
Also, you might make sure the wire grips are tight and correctly gripping the lug nut.
Edited by hosspuller 2005-07-09 11:42 PM
RTSmith
Posted 2005-07-11 9:54 AM (#27887 - in reply to #27834)
500100100252525
There was a redesign on these. An '01 should be old style, so the replacements should work much better.
RTSmith
