how to "see" a signature; how to use emoticons
Last activity 2005-10-13 1:57 PM
1 replies, 2410 views
pegasus
Reg. Mar 2005
Posted 2005-10-13 1:26 PM (#31712)
Subject: how to "see" a signature; how to use emoticons
Help please, how do you see the signature referred to in some posts, and how do you put the emoticons in a post? I am a registered user on my home computer. Thanks.
roadranger
Reg. Oct 2005
Posted 2005-10-13 1:57 PM (#31715 - in reply to #31712)
Subject: Bison 8310 and 3/4 ton pickup
I can help with this one!
Up in the Blue Bar on top of screen, click on 'settings'.
Then click on 'edit profile'.
In that window you'll see little 'radio boxes' that you click to make a dot appear that will turn these functions on or off. Lot's of other stuff to set up too.
For emoticons to work, 'rich text' has to be enabled.
In addition; If you want to show spacing and paragraphs in your post, instead of one run-on line, click the 'disable HTML' box just below the post window.
Hope this helps...
Edited by roadranger 2005-10-16 12:09 PM
