Remove Black Streaks & Brighten Bare Aluminum Trailers
Jump to page : 1 2 3
Now viewing page 3 [25 messages per page]
Last activity 2007-06-18 11:31 PM
58 replies, 25461 views
AbbyB
Posted 2007-06-10 4:57 PM (#62093 - in reply to #61136)
Subject: RE: Remove Black Streaks & Brighten Bare Aluminum Trailers
NTO, they don't know not to mess w/you!!  LOL  I, too, got & used the aluminum cleaner.  The first 2 pics are befores & the 2nd (this is providing I can get them to post!) will be afters.  NOW - unfortunately, it was later in the day & the trailer is more shaded in the afters so you can't tell the diference as well.  And for the skeptics, I moved the trailer between the before & after pics so background won't be the same either!!  If I'd known they were going to be scruntinized so much, I'd been SURE I took all pics from the exact same location/angle/time of day/etc etc!!
carsandhorses
Reg. Jun 2007
Posted 2007-06-11 7:57 AM (#62122 - in reply to #61136)
I used the Black Streak Remover this week to wash my entire 4 Star trailer, It has stainless steel, alum. and painted surfaces. I was NOT pleased with the results that I received. It did remove the bugs off of the front and some road grime and a small amount of oxidation , but not much to remove the streaks and brighten the overall look. DH
Longrider
Reg. Oct 2004
Posted 2007-06-16 12:51 PM (#62364 - in reply to #61136)
10010010025
I received and used the trailer brightener. It WORKS! Made the aluminum shine like a new silver dollar. Very pleased with the results.
Lobo56
Reg. Mar 2006
Posted 2007-06-16 3:10 PM (#62366 - in reply to #61136)
My 4-star is bare aluminum no painted aluminum on it.  I received the brightener on Thursdays used it today and wow it made my trailer look as good as the day I bought it.
Edited by Lobo56 2007-06-16 3:12 PM
captclank
Posted 2007-06-17 7:08 PM (#62396 - in reply to #61136)
lobo56 and longrider: How much elbow grease/effort was needed? Thanks
Longrider
Reg. Oct 2004
Posted 2007-06-18 6:45 AM (#62401 - in reply to #61136)
10010010025
Very little elbow grease required.  I used a carwash brush (from wallyworld) to apply the brightener.  The only incident was that I had not mixed the solution strong enough at first, so I added more to the mix.  It started foaming after application then, I let it work for approximately a minute and rinsed off with a garden hose.  Some areas that were quite dull, I went back over again.  Make sure you rinse off thoroughly.  EASY!
MichaelD
Reg. Apr 2004
Posted 2007-06-18 8:07 AM (#62406 - in reply to #61136)
Ordered some on June 12th. Haven't received it yet. Will report back once I've used it.
Mike
KAB
Reg. Jun 2007
Posted 2007-06-18 11:27 PM (#62445 - in reply to #62122)
Originally written by carsandhorses on 2007-06-11 7:57 AM
Did you dilute the Black Streak Remover?
You need the Aluminum Brightener for the Aluminum..not the Black Streak remover..
KAB
Reg. Jun 2007
Posted 2007-06-18 11:31 PM (#62446 - in reply to #62093)
Originally written by AbbyB on 2007-06-10 4:57 PM
Looks great!
